-   -   Distributor (https://www.offshoreonly.com/forums/general-q/169554-distributor.html)
SCARAB98 09-24-2007 06:57 PM
Distributor
Need new coil & distributor module 502 w/whipple.Go with msd or back to stock ?
rdoactive 09-25-2007 07:56 AM
If you're not fouling plugs at idle, a new ignition wont do anything.
If you are, consider a couple manufacturers. MSD does not seem to be the most reliable.
SCARAB98 09-25-2007 04:30 PM
Boat runs fine.The tach is going all over the place.
turnerrd 09-25-2007 10:37 PM
HuH. I remember someone telling you they thought it was a coil a month or so ago???? He must have been smarter than he looked.
ghittner 09-26-2007 12:16 AM
Umm Me? Maybe not? A coil to start. Use an MSD blaster 3 coil.
Re: tach needle jumping
I've seen the coil cause this more than once
