Does anybody have the EVC spec for the ZZ502 cam?
I called Jim Pace performance today and they did not know the info. I hunted the internet and no success.
Can someone inform me on the ZZ502 cam (GM 12366543)spec, particuliarly: IVO IVC EVO EVC Thanks - Gary |
224/234
527/544 110lsa i can double check that in the morning. |
BY U BOY - I was looking for the spec on the intake valve opening and closing plus the exhaust valve opening and closing which usually comes on the cam card.
Anybody out there know this? |
Originally Posted by GNJ
(Post 2286588)
(Post 2285645)
12366543 Steel Hydraulic Roller
This steel roller is for 502/502 special engines. (Must use distributor gear P/N 10456413.) The duration at .050” tappet lift (intake/exhaust) is 224/234; and maximum lift with 1.7:1 rocker ratio (intake/exhaust) is 527/544. Valve lash is zero/zero and lobe centerline is 110 degrees. As stated. Thats all I can find right now.:D |
Pwrbt33 & Rotax 454: I have them in my 502's and am suffering from reversion. I am trying to find out the:
IVO IVC EVO EVC Does anybody know this? Thanks - Gary |
If you cant find a cam card have an engine builder put a degree wheel on the front of the engine and check it that way!
(Post 2289634)
1 Attachment(s)
GNJ,
This should help. Bob |
Thanks Bob, Saves me looking for that missing cam sheet. From my experiences, his issue of water reversion is more a result of his exhaust manifold water dumping, or lack of.
| All times are GMT -5. The time now is 01:08 AM. |
