525SC Serial Numbers ???
Motor is a 96. Where can I find the Mercruiser serial numbers ? Just want to varify it is a real 525SC.
http://mercruiserparts.stemtostern.c...nceengines.asp
PHP Code:
Did they offer this motor in 96? Also, where can I find the serial number on the motor???
Thanks |
Originally Posted by G Man
(Post 2289189)
Thanks |
Numbers should be on the side of the block near the starter.
Darrell. |
On my '96 525SC, I couldn't find the number either until I tore it apart. There was no riveted tag, but the engine was still wire sealed on the intake and crank pulley bolts.
I finally found it when I rebuilt the top end. The serial was stamped into the block behind the fuel filter seapump bracket, just below the cylinder head, if I remember correctly. Also the stamping was only about the same size as the type you are reading now. |
| All times are GMT -5. The time now is 08:16 PM. |
