-   -   Raw Water Strainer Leaking (https://www.offshoreonly.com/forums/general-q/169939-raw-water-strainer-leaking.html)
OhioRiverCigarett 09-29-2007 01:51 PM
I have a 1981 33 foot cigarette with "original" raw water strainers. I am not sure who made these, but they are brass with a clear plexiglass top and a single 3/8 bolt down through the top. I had to machine new plexiglass tops (1/2 in thickness).
How much pressure should it stand up to? Do you need to permitex the top in. It has a flat rubber gasket around the outer edge. It is leaking around the edge.
Thanks for any help:ernaehrung004:
