Stuck Valve ???
I've stuck an exhaust valve for the second time. It's more than a clearance issue. The valve stem had plenty of clearance in the guide when it was assembled. For some reason it seems like the guide shrinks and the valve sticks. It has always happen when the oil is not up to temp. Dart Heads with Mag/bonze guides. The last time , the guide had a dark color inside the guide. You would think it would be shinny from the valve stem. The guides were honed to size instead of using a reamer. Can't see where that should make any difference.
Water temp runs 150* Anyone run into this?????? |
How do you know the valve stuck, what were the symptoms? It seemed to be running good yesterday, was there deterioration in performance after the sticking event?
Anyway, things that come to mind for me are clearance, valve train geometry (side loading valve) , running lean combined with running too hard before the oil is warmed, broken inner spring or wrong open spring pressure, broken push rod guide, bent valve stem, reversion causing some corrosion on exposed stems during non run times. |
Oh chit....I was thinking about you just a couple days ago, guess this post tells me how things have been going. Good Luck.
Russ C. |
I had a similar problem years ago.
After sticking an exhaust valve (same cyl) over and over, tried different guide materials, clearances etc. we finally found the cause after a complete tear down... there was a chunk of rubber impeller that made its way into the block and water restricted flow to the head. |
Dave, At first its just a hipcup when I first get on plane. Then it start to happen more and more. The valve doesn't totaly stick open at first, its just slow closing. When the valve starts to stick you feel the lose of performance big time. Every thing you mention has been look at. I have 02 sensor in the exhaust , so I know the air/fuel is fine. Matter of fact at idle its rich, around, 10. The only thing I can think of if my egt's are high. Usually in a car when someone sticks a valve its because they got the motor hot. So thats out in this case. Last time it happen I thought about leaving the seals off the exhaust valves, but shouldn't have to do that. I guess I get it figured out.
Originally Posted by Biggus
(Post 2289787)
Any engine builders out there? Ideas??
How about wrong or upside down head gaskets Mike? Is it always the same 2 exhaust valves? One one each side.
Originally Posted by blue thunder
(Post 2289856)
Originally Posted by Noise Pollution
(Post 2289794)
Actually, engine coolant temperature is usually not the problem. The problem is with combustion chamber temperature. If the one cylinder is a little lean, or the timing is retarded, etc and the valve itself, not water temp, is too hot, the valve actually expands and sticks in the guide. You mentioned that your EGT was high .... this is probably a clue to the real cause. A blocked water passage to the area involved might make it worse, but I bet if you track down your egt problem, you will stop sticking valves. Also, what is the actual guide clearance you are running ? Honing the guides is the preferred method of sizing. Hope this helps, Bill Koustenis Advanced Automotive Machine Waldorf Md |
Originally Posted by BillK
(Post 2289972)
Noise,
Actually, engine coolant temperature is usually not the problem. The problem is with combustion chamber temperature. If the one cylinder is a little lean, or the timing is retarded, etc and the valve itself, not water temp, is too hot, the valve actually expands and sticks in the guide. You mentioned that your EGT was high .... this is probably a clue to the real cause. A blocked water passage to the area involved might make it worse, but I bet if you track down your egt problem, you will stop sticking valves. Also, what is the actual guide clearance you are running ? Honing the guides is the preferred method of sizing. Hope this helps, Bill Koustenis Advanced Automotive Machine Waldorf Md Is there a number I can call you? Thanks Mike |
Mike,
You can call me Monday at 301-843-5700. I have not seen any problems with the Dart guides "shrinking" but 90% of the engines I see are automotive applications. Have you measured the valve and compared it to a new one ? What brand valves ? Is the valve job done properly ? Too narrow of an exhaust seat will not allow enough heat to get transferred out of the valve into the cylinder head. Too much seat runout will do the same. Bill |
(Post 2290121)
Mike,
You can call me Monday at 301-843-5700. I have not seen any problems with the Dart guides "shrinking" but 90% of the engines I see are automotive applications. Have you measured the valve and compared it to a new one ? What brand valves ? Is the valve job done properly ? Too narrow of an exhaust seat will not allow enough heat to get transferred out of the valve into the cylinder head. Too much seat runout will do the same. Bill I'll call late afternoon. |
Are you running cross overs? I had the same problem on a boat I had with triple 510's. It happened on each of the engines. What I did after the recomendation of several good engine builders in Michigan was put the stock water pumps and thermostat housings back on, and it took care of my problem. What I was told is in the colder Michigan water It is important to keep engine temp at a constant. I am not sure what the water temps are like in Delaware.
I hope this helps you out. It took care of my problem. |
| All times are GMT -5. The time now is 02:15 PM. |
