-   -   outboards? (https://www.offshoreonly.com/forums/general-q/170000-outboards.html)
liftedch3vyguy 09-30-2007 01:08 PM
outboards?
I previously owned a 24ft cheetah with a big block i/o. i am interested in buying a 20 ft or around there stoker with an outboard but really dont have much knowledge about outboard motors. I was kinda just wondering if someone could tell me what the pros and cons and which models to stay away from. thanks.
MOBILEMERCMAN 09-30-2007 02:19 PM
Outboards can give many years of good service and when set up right can be run hard for extended periods. What ever you look at do a compression test. There should be no variation from cylinder to cylinder. Check for signs of getting hot , burnt paint around heads, burnt insulation in cowling covers. If it has been overheated stay away. As you might have guessed I would suggest a Merc. Good luck.
Jim
tassie boy 09-30-2007 04:16 PM
go for a big merc , if looked after you will get many years of reliability and they pull like a 16 yo boy. but they sound like a 3cyl daihatsu that has run out of oil. cheers tassie boy
