fluid damper
Is a fluid harmonic damper worth the money?
Is a 502 cid internally or externally balance and what size it it. |
if it is a stock 502, it is externally balanced and I beleive you need to run the external balanced dampener.
Ken,
Unless something is wrong with your original damper, I dont see any real reason to change it. The Fluid damper will not do a thing for you as far as power goes. If you are building a performance engine and want to upgrade the damper, I personally would go with an ATI unit. The 502 is externally balanced, your damper supplier should be able to tell you which one to get. Bill Koustenis Advanced Automotive Machine Waldorf Md |
| All times are GMT -5. The time now is 10:01 AM. |
