| boatman747 |
10-08-2007 06:24 PM |
drive fliud
#4 speedmasters . Last time I took out my boat my drive resivoir filled up over one quart .What can cause this? Is this normal. It never happened before. The only thing that was different was I was running in fresh water instead of salt? I drained the fluid. I noticed a slight hint of water intrusion in the drive fluid but not a quart.When I drained the fluid the bottle would not drain. 6 days later it finally drained. All vent / drain screws were removed.What do you think?
