Mechanical Fuel Pump 500 EFI?
I have a pair of 2002 model 500 EFI's and I fired them up on the hose this weekend and found that one of the mechanical fuel pumps that mounts to the sea water pump is leaking oil out the side. I always service the pump with freash oil and a new gasket between it and the water pump every year but it is not leaking at that gasket between them but out the side of the pump.
I need to replace it and was wondering if a standard pump from a local auto store was the same. If so does anyone have a part number to reference? Thanks |
Dock,
I think the Merc number you are looking for is 842429a01 |
Originally Posted by BobbyB
(Post 2301352)
Dock,
I think the Merc number you are looking for is 842429a01 That looks like the Merc number I found online but I did not know if a standard auto fuel pump would cross over with this one. Dock |
The auto fuel pump will not have a nipple installed for the overflow tube. If the diaphragm fails it will dump fuel in the bilge.
Originally Posted by insptech
(Post 2301512)
Thanks I don't want that so I'll order from Merc. Much appreciated guys. |
Check out KEith Eickert. He has a bullet proof pump that is much better than the Mercury one. Also the pump arm is differant than any automotive style pump.
Originally Posted by CIG3
(Post 2301761)
| All times are GMT -5. The time now is 12:06 AM. |
