-   -   head studs sealers (https://www.offshoreonly.com/forums/general-q/171168-head-studs-sealers.html)
Ken N 10-15-2007 04:19 PM
head studs sealers
What is a good thread sealer for head studs. Mine pass thrugh into the waterjacks.
Vinny P 10-15-2007 05:22 PM
I use Permatex aviation cement. The brown stuff that sticks to everything when you are working with it. Nasty stuff, but it works.
Pwrbt33 10-15-2007 05:37 PM
I also like the permatex #2 sealer as well. Both do good jobs.:D
BillK 10-15-2007 07:11 PM
Ken,
I use Permatex White Teflon, but have also used the #2 with no problems in the past. One thing that I found with studs is that they seem to seal better if you brush a fair amount of whatever sealer you are using into the hole in the block along with putting it on the threads of the stud. I have yet to figure out why, but for some reason compared to bolts, a lot of the sealer seems to get wiped off the stud as you thread it into the hole.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Donman 10-15-2007 09:53 PM
Originally Posted by BillK (Post 2306711)
Ken,
DITTO . :ernaehrung004:
Griff 10-16-2007 02:01 AM
I've used permatex high temp thread sealant and the ARP thread sealant. If you have ARP studs, then get their sealant and follow their torque recommendations.
http://store.summitracing.com/partde...5&autoview=sku
Ryan00TJ 10-16-2007 07:17 PM
I've always used Permatex #2 and have never had a leak.
Ken N 10-17-2007 03:41 PM
Can teflon tape be used along with the brush on type of teflon.
OldEliminator 10-17-2007 09:33 PM
I was told to use blue loctite and plenty of it, any ideas on this as a head stud sealer?
mrhorsepower1 10-19-2007 05:58 AM
ARP thread sealer works well.
