-   -   Dumb question here! (https://www.offshoreonly.com/forums/general-q/171728-dumb-question-here.html)
smdude 10-23-2007 06:04 PM
Dumb question here!
Getting ready to install 502's in the Fountain,(never done this in a boat), Not sure about the coupling plates, should I leave them a little loose to fit up on the Velvet trans spline, or tighten them. With the bolts drawn close I can fell about .020 of movment. Checked everything for fit and looks good.(bellhousing to trans, bellhousing to motor). Thanks for any help, cause to tighten the bolts later, I would have to go threw the starter hole, and that doesn't sound fun. 83 Fountain 502's, TRS, Velvet trans. Harry
[email protected] 10-23-2007 08:14 PM
You could do it either way, the down side to through the starter hole is if you break a bolt it will be less fun trying to get it out of the flywheel
