Valve Covers
Looking for options on a new set of valve covers for a buddy of mine. He had a midwestern engine shop build up his '96 330HP 7.4L's with Brodix aluminum heads, Merlin single plane intake, roller cam, roller rockers, and CMI E-tops. The shop butchered the stock valve covers to get them to fit and now they are leaking. What options are out there that will clear the rocker arms and headers? The shop powder coated the stock covers Merc blue and he would like to stay with that color if possible. Thanks.
1 Attachment(s)
I have these..double thick gaskets and they clear..$100/set..Dave I have two sets
i have a set i bought that are crome, and say mercruiser on them 75.00 free shipping
Give Fred at Trick Marine a call. They have vaulve covers in many colors that will fit.
Dail |
I have a set of Eddie Marine tall covers used about 5 hrs.
Stock covers should have fit with no problem. Just needed to grind off the oil drip tabs and the corners of 2 rocker arms.
1 Attachment(s)
I have KE 2 piece covers. Look great, clear rockers easily, BUT they leak really bad. I have to silicone them shut to stop the leaking. So much for easy thumb wheel removal.:mad::mad:
1 Attachment(s)
kinda looks like my set up and with the gil exhaust manifold im kinda limited to stock shape covers, i had bought some really trick carbon fiber's and they dont clear the gill manifolds
Originally Posted by checkmate454mag
(Post 2325887)
Originally Posted by offthefront
(Post 2326696)
The rails are bad .... There was a production issue when KE did not have control of the company .... You can buy new rails and O rings and be good to go ...m
:ernaehrung004: Next thing I have to do is figure out how to rig an overflow bottle to the breathers. When I beat it up for a long time, I get a bit of oil spewing from the breathers. I hate oil leaks!! Anyone got any pictures of their set up? |
(Post 2328235)
I didnt know about that. The strange thing is that I got a call from Tony @ KE today, He offered to replace the rails for a reasonable price. Thanks Tony and KE.
:ernaehrung004: Next thing I have to do is figure out how to rig an overflow bottle to the breathers. When I beat it up for a long time, I get a bit of oil spewing from the breathers. I hate oil leaks!! Anyone got any pictures of their set up? Can you let me know how the new rails work out? I have the same issue and even got a second pair of rails from Hardin and they still leak. I also used the recommended gaskets. |
Originally Posted by Advantage 27
(Post 2328287)
Checkmate,
Can you let me know how the new rails work out? I have the same issue and even got a second pair of rails from Hardin and they still leak. I also used the recommended gaskets. When did you get your new rails? |
(Post 2328352)
Oh no...Tony @ KE/Hardin assured me this will fix them for good. Unfortunetely, I wont know for sure until May. I hate winter!!
| All times are GMT -5. The time now is 10:46 AM. |
