-   -   valve cover breather (https://www.offshoreonly.com/forums/general-q/172883-valve-cover-breather.html)
Ken N 11-08-2007 03:52 PM
When useing a valve cover breathers are PCV valve still used.
turbo2256b 11-08-2007 06:31 PM
I have installed PCV systems onn all my boats
Ken N 11-08-2007 07:27 PM
Can i use both system.
turbo2256b 11-08-2007 08:16 PM
pcv should pull air from the breathers through the engine
Ken N 11-10-2007 01:18 PM
Can two breather be used one on each side.
turbo2256b 11-10-2007 02:05 PM
if the PCV pulls air from the lifter valley is perferable. The PCV should be as far from the breathers as possible. Is this a carb application?
