throttle body
Is there a throttle body upgrade for a 1999-502 MPI. If so who makes and sells it.
I did send an e-mail last friday to Arizona speed for the same thing, but till now no answer yet.
Harry |
Harry
If you get a answer let me know |
There is no aftermarket throttle body that bolts on a 502 mpi that exist that I can find,the one azsm sells is for a hp500 and will not work. However I can bore yours out and install larger throttle blades,its worth approx 10 hp/ft lbs of tq on a modified motor (thats what I saw in back to back testing on the dyno) Smitty
How much? I'm pulling mine out tonite to re-ring and freshen up for next year.
articfriends
How much will it cost for the boreing and blade work. |
You both have mail. I'm going to be gone from this saturday until sunday the following week so if you don't hear back from me I'll get back with you asap,Smitty
Ken,the bored out throttle body is worth more than 10 hp on your blower motor too,unfortunately after we made 1115hp on the dyno we got so excited we never bolted the stock throttle body on to see how much power we would lose,Smitty
Hey Smitty it's good to see you got that T/B upgrade going. I did this last spring and am finally getting around to putting it all together.
Did you run into any problems getting the EFI to work right with more air at given throttle settings? I am looking for a base map to start with, worried about being lean. Looks like you got that thing close to the century mark |
Originally Posted by midwest272
(Post 2338673)
| All times are GMT -5. The time now is 04:39 PM. |
