-   -   silent thunder 223 formula (https://www.offshoreonly.com/forums/general-q/174366-silent-thunder-223-formula.html)
formula 382 sr-1 12-03-2007 06:05 PM
1 Attachment(s)
I drilled holes in our 272 with the biggest hole saw that would fit in the trim ring . Ours had 383's 425 hp in it sounded great 69.8 on GPS.:D
farmermoe64 12-04-2007 03:24 PM
i can see the small piece maybe .25 inch plywood from the rectangle exh hole is there another baffle behind that one. is there 2 in each box or 1 . i think i will just drill it out not knock them completely out. so if theres 2 should i do both
