-   -   Fast Glass risers-problems, info? (https://www.offshoreonly.com/forums/general-q/174447-fast-glass-risers-problems-info.html)
WHIPLASH 12-01-2007 08:13 PM
I bought a boat with a 454 magnum (89) and it has fast glass stainless risers on it. As i'm replacing the old, and possibly rusted out cast iron manifolds with aluminum GLM ones, a friend of mine told me to get rid of the risers. He claims they warp, especially after removing them and putting them on a new manifold, and leak water back into the engine. Has anyone else had or heard of this problem?
f311fr1 12-01-2007 09:21 PM
I had a friend run a set for about 10 years. Check the flange with a straight edge and feeler gauge.
Ryan00TJ 12-02-2007 10:34 AM
I've been running my FastGlass stainless risers since the late 80's on my SBC. I modified them last year into long risers from the standard short ones. I've had no problems with mine. I don't see how just removing them and putting them on a new manifold could warp them? Unless they saw extreme heat I don't think it's possible. As mentioned check the flange for straightness and make sure good gaskets are used in the riser manifold connection. I like to run the blockoff plates and route the water thru the manifold to hose to riser.
http://img140.imageshack.us/img140/8...iserqt1.th.jpg
http://img126.imageshack.us/img126/5...ensikp9.th.jpg
