check valve
I plan on installing a Areromotive 1000 fuel pump on a 502 EFI engine. Where is the best place to put a check valve before the pump or after.
Hi Kenneth,
Best after to keep fuel in the pump? What reg are you using?:D |
1 Attachment(s)
I installed my check valve on the output side of the machanical pump. That way, if I am running on only the mechanical oump, fuel doesnt go back through the electric pump. When they are both on, fuel flows as normal. It may be a bit hard to see. The check valve is the red piece hanging down off the output of the mechanical pump.
Hey, Vinny, how about a shot from a little further back to see the pump? Those lines and fittiings look great...did you use them for hydraulics too?:cool-smiley-011:
1 Attachment(s)
This is the only other shot I have of the electric pump. I can take others if you can be a bit more specific.
Vinny P.
I am using the Aeromotive Platinum series #P/N 13153 regulator. |
1 Attachment(s)
Ken,,
Here is the pic of the regulator we spoke of. |
| All times are GMT -5. The time now is 11:57 AM. |
