Prop Reccomendations Please... 90 Scarab 454 Mags
Hello.
I am running 3 blade 25's and not happy w/ acceleration. Some are recomending 3 and other 4 blade. Now when I accelerate, The tachs on the 454 mags are only @ 4,000 rpms full open and cruising which I know is hard on the engines... What should I run for a lil better performance??? Also... where is the best place to buy props... and should I go used?? Thank you so much for your advise! new boater |
need more info
what size boat,drive ratio,what prop? 4000 rpm's is to low for that motor. you should be in the 4600 to 4800 rpm range. try a mirage + 23p. also post this in the prop section you will get more help. Call brett at bblades or julie at throttle up both are members on the board. Good luck. |
A23 mirage should bring you up 400RPM,merc says 42 to 4600rpm is were you should be with a 7.4 454 motor.
and I do have a set of 23 mirages that have acouple of hours of use on them. PM if your intrested |
My 31' Excel with 454 Mags runs 5000 RPM with 23P mirage 3 blade.
Originally Posted by shotjock
(Post 2360223)
Hello.
I am running 3 blade 25's and not happy w/ acceleration. Some are recomending 3 and other 4 blade. Now when I accelerate, The tachs on the 454 mags are only @ 4,000 rpms full open and cruising which I know is hard on the engines... What should I run for a lil better performance??? BTW, 4000rpm is way too low for WOT. Either you have the wrong sized props or your engines are real tired and in need of a rebuild. |
Yes, Sorry,
It Is A 31xcel. With Bravo 1 Drives, And When Trim Is All The Way Down And On Plane, Only Getting About 4000 Rpm At Full Throttle. The Motors Have New Top Ends 40 Hrs Ago. |
OH, AND YES, I GUESS I WILL BE SHOPPING FOR SOME 23 P'S LOOKING AT THE RECOMENDATIONS SO PLEASE LET ME KNOW HOW MUCH YOU WOULD CHARGE FOR THEM.
THANKS! FRANK [email protected] |
(Post 2361766)
THANKS! FRANK [email protected] I have the same boat, 1992 31 Excel 454 mags. I have 23p 3 blades but I'm trying to find some 22p 4 blades to try.. |
So... Should I then be looking for the 22 4 blade and just skip the 23's all together???
Any advise is greatly appreciated! |
| All times are GMT -5. The time now is 03:51 AM. |
