rocker arm geometry
When installing an after market set of heads (Dart Iron Eagle 308) and a set of roller rocker arms, how far do I screw the Polly locks down, keeping in mind the back lash adjustment (1/4 turn down after zero lash). I do not know how to work the rocker arm stud adjustment with the adjustable push rod to get the right geometry.
The way I understand it as you rotate the cam the sweep of the roller tip should be in the center of the valve stem.
I have set up rocker geometry more than a few times. It is difficult for me to explain just how to do it correctly. Maybe this link will help you out.
http://www.compcams.com/Technical/FAQ/FAQPushrods.asp |
geometry must be right on
Originally Posted by Vinny P
(Post 2365180)
Originally Posted by Kenneth Neuhaus
(Post 2364891)
I use a light gauge valve spring and I color the tip of the valve stem with a black marker then adjust the pushrod to get the roller to smudge the marker as close to the center of the valve stem as possible when rotating the engine one complete turn. Now measure the pushrod and you have your lenth. Then follow the correct lash adjustment. Gerry |
rocker arm geometry
I have a set of addjustable push rods.What I need to know is where to set the rocker arm at the top middle or bottom of the rocker arm stud. Where to start, do I adjust them both up and down to get the rocker in the middle of the valve stem.
(Post 2365267)
AS posted above. http://www.compcams.com/Technical/FA...inGeometry.asp |
Gerry- get out of here.....you are a kerosene burner now! just kidding brother!:drink:
Originally Posted by mrhorsepower1
(Post 2366850)
Sak aready said he would buy ya steaks if ya visited him I say both of you guys come help me drive my tub. I will buy the lobsters and Coronas!:D Sorry dont mean to Hijack this Deal! |
Originally Posted by KNOT-RIGHT
(Post 2367982)
Wheres the Love?
1 Attachment(s)
Nice Rob:drink:
Rob, what's that thing in the middle of your diagram a mini train car de-railing.?.:eek:
1 Attachment(s)
Originally Posted by 1CE
(Post 2371350)
Its a different king of fulcrum , It gives the basic view of the tip:D http://www.hi-flow.com/HPYT4/metery01.jpg |
never mind the fulcrum tell us about the cool 3-valve heads !
1 Attachment(s)
(Post 2373418)
Barry Grant made them,SBC |
| All times are GMT -5. The time now is 05:11 AM. |
