-   -   is it a 302? (https://www.offshoreonly.com/forums/general-q/176006-302.html)
flashhat 12-23-2007 05:09 PM
is it a 302?
3 Attachment(s)
Just started tear down on the motor for a 16 donzi.
What is it?
I know it is Ford, approx 1972
says interceptor, 190 hp.
Heads have 302 stamped on them.
Going to send heads and block to machine shop.
What would be recommended to do to this motor.
Easy upgrades, intake? carb? heads? distr? manifolds?
Not looking to make crazy HP due to small boat just easy and not to much $$$ while at this point.
Thanks,
OLSKOOL72 12-24-2007 12:36 PM
Sure looks like a 302
From the pics, its either a 302 or 289. You can check the bore and stroke now that the heads are off. 289=4.00x2.87 and the 302 is of course 4.00x3.00 stroke. By the look of the sludge-oil-stains, it may have been a swapped out car motor. There are all kinds of mods you can you to that little motor to really make it scream. At the least, I would do a nice rebuild, with quailty machine work, up-grade to flat-top pistons, install larger valves in the heads, Go with some SS 1.94int. & 1.60ex. a hot little hyd. cam, around a 280/480, then dump that intake and 2-popper for a nice alumn. intake, like a edelbrock performer rpm, and holley 600cfm 4-bbl. You will have 300hp all day. FYI, we just finished a project for a customers original hollman-moody Donzi-swwet-16. We replaced the little 289 with one of our 450hp-347cid stroker 302's. Still playing with props on that volvo, but it's seen 76mph while sitting at 5700 on the rev-limiter.
2112 12-24-2007 01:03 PM
289s stopped production around 67 or so. Definitely a Windsor head. The best stock Windsor head is from a 69 351. They are a direct bolt on and not much $ Of course there are tons of great heads out there for more.
If you stay with stock heads, in addition to the above upgrades, remember screw in studs and grind off the exhaust bump in the exhaust ports.
flashhat 12-25-2007 05:13 PM
302
just measured, it has just over 3" stroke, so it is a 302.
Now how to tell what the heads are?
thanks,
OLSKOOL72 12-26-2007 03:47 PM
302??
Over 3" stroke?? Than its not a 302. The next nominal stroke for a wedge head sbf would be 3.50 and than you would have a 351w. Double check your stroke again. Also, if you post the casting#'s on the heads, I'll tell you what you have. Mark
OLSKOOL72 12-26-2007 04:42 PM
Originally Posted by fredefox (Post 2383881)
If heads are stamped with '302' then they are from a 302. Not likely that the engine is a 351 with 302 heads.
Why not?? I have had plenty of engines come through the door with 302 heads on a 351. Espesially if they were trying to low-buck some compression ratio. I also had a 302 once come in with a 351 cam in it, that no one could ever get running right. As they never knew the 351 had a different firing order than a 302.
OLSKOOL72 12-26-2007 04:46 PM
Also i never doubted they were 302 heads. Just going to tell the guy what vintage they were if he supplies the casting#'s. But if he has over 3 inches of stroke, its obviously not a 302.
flashhat 12-26-2007 07:16 PM
Got a good measurement, it is 3" stroke.
Here is what I found on the block and Heads.
"Pomoco" and 302 on both
On heads, 8H13 302 and 8H14 302
What is recommended to do or replace on block and heads to make reliable modest HP at best price?
Thanks,
2112 12-26-2007 08:29 PM
FOMOCO =Ford motor company
should have a C, D, E or F. C built in the 60's, D in the 70's, E in the 80's, F in the 90's.
Late 60's heads were probably the best for the small combustion chambers and decent size valves.
flashhat 12-27-2007 06:59 AM
The heads have an "E" stamped on them,
Thanks,
2112 12-27-2007 12:24 PM
Those can be made to flow but they have big chambers and it has been my experience that Windsors like tight combustion chambers. Obviously cast in the 80's for example; E8 means cast in 1988
excalibur32 12-27-2007 12:50 PM
Great boat anchor's! swap for a Chevy!!! Ok guy's you may begin!!!!!!!!!!!
OLSKOOL72 12-27-2007 04:03 PM
2112,
He must be reading the casting#'s wrong. In the pic, it appears it has adjustable rockers. And that was long gone by the eighties.
2112 12-27-2007 08:33 PM
For a 16 footer, I can't imagine too many options better than a SBF. If he wanted he could turn it into a monster of an engine. Even if he is on a budget, he can exceed 1HP per inch and have a hell of a ride.
It is an oldie and needs updating but Pat Gahnal's book of Ford V-8s is a good place to find out how to build a stout 302.
PS those log manifolds will rob you of most of the power you try to get out of what you have.
Joe92GT 12-27-2007 10:39 PM
Why bother with stock heads? There are soo many SBF heads on the market right now that flow 10x better. Don't even think about porting, invest the money in new heads.
2112 12-27-2007 11:39 PM
Good advice.......unless you have more time than $$
jayhawk261 12-27-2007 11:55 PM
351w has larger head bolts than a 302. To run the 302 heads on a 351w, the head bolt holes would need to be drilled out. Not saying it hasn't been done, but it most likely wouldn't be worth it for any potential gains.
This looks to me like a 302. A 351w has a much wider intake manifold. It is very obvious.
Go with aftermarket heads on a fresh build. The stock Ford windsor heads are terrible for air flow. If you want it to breathe, you'll either spend a ton of money on head work, or spend that money on a nice clean set that will still flow better out of the box.
jayhawk261 12-28-2007 12:01 AM
The 351W cam does have a different firing order than the old 302. Once ford came out with the HO 302 in the eighties though, they used the same firing order as the 351W then.
I remember the first engine I built was a 351W. I was 16 and was just learning about engines. Me and my buddies had the hardest time trying to figure out how the cam could determine the firing order!:D We figured it out eventually!
flashhat 12-29-2007 07:23 PM
2 Attachment(s)
Here are photo's of the head castings.
flashhat 12-29-2007 07:31 PM
2 Attachment(s)
sorry, loaded wrong photo's
these are correct
flashhat 12-29-2007 07:32 PM
1 Attachment(s)
here is one of the block
Thanks,
2112 12-29-2007 07:55 PM
are you on a tight budget?
The other's suggestions on after market or even Ford SVO (now called Ford Racing) heads will save you tons of work and make way more power, more reliably
