-   -   Procharged 496 stroker (https://www.offshoreonly.com/forums/general-q/176050-procharged-496-stroker.html)
253checkmate 12-24-2007 12:04 PM
Has anyone run a 496 stroker supercharged? I am currently running a gen 6 454 mag. engine with a 5p.s.i. Procharger setup. The engine has 503 hours so I was looking to upgrade for more hp. I know people have had good things to say about n/a strokers but I could not find any threads regarding 496 s/c strokers. I did not know if the .060 bore is too much for 5 p.s.i. of boost. I was even looking into going n/a with a bowtie block with more cubes but I don't think it's in my budget for next spring so I'm looking at my gen 6 again with the Procharger. I currently have a new set of AFR 315 cnc heads and am looking at some top shelf internals but I am concerned with the cylinder wall thickness with the boost. Thanks.
Velocity Vector 12-24-2007 01:35 PM
http://www.offshoreonly.com/forums/s...ight=blown+496
OLSKOOL72 12-24-2007 01:44 PM
good to go
I would not bat an eye to pump 10PSI through a +.060 gen-6. It will live forever at 5psi. The Cyl. walls are not as thin as some think. Or none that we have sonic checked anyway...
