-   -   never seize (https://www.offshoreonly.com/forums/general-q/177301-never-seize.html)
BY U BOY 01-12-2008 12:14 PM
never seize
Is there a special anti seize that i should use with stainless and aluminum?
Chris Sunkin 01-12-2008 02:14 PM
Permatex Nickel #771.
SS, Ti, nickel alloys, etc. It will also work on aluminum but it's not necessary- ordinary anti-seize is suitable except in hi-temp applications.
BY U BOY 01-12-2008 02:47 PM
So the permatex is ok to use with my exhaust manifold bolts?
Strip Poker 388 01-12-2008 04:59 PM
I was told the copper/brown wasnt good if salt water gets on it? And to use it on spark plugs on alumin heads because of the heat..
Ryan00TJ 01-12-2008 05:31 PM
I've always used ordinary antisieze and have not had a problem except when I did not use it. I use it on the spark plug threads, head bolt area above the threads that contact the aluminum heads. I've had them sieze there before with no antisieze. Really any place where two dissimilar metals are used.
Ruaraidh 01-12-2008 05:40 PM
Bostik Neverseeze was always what we used at Cosworth for exh threads and spark plugs.
Great stuff with different grades of nickel loading including Nuclear reactor grade.....
http://www.neverseezproducts.com/bostik.htm
Chris Sunkin 01-12-2008 07:54 PM
sure
