Tall valve covers for 496
Does anyone know of a tall valve cover for the 496? or maybe a spacer? Roller rockers and poly locks are hitting on mock up. Need about .300-.400" We really hope we don't have o move the coils.
Mike |
call Mrhorsepower...Dean Gellner put roller rockers on my 496 and used stock valve covers had to do some machining I am sure he can help you>>>
The 502 MPI's have an "oiler" cast into the covers and has to me trimmed to allow clearance for roller rockers ...m
Get out the dremel and start grinding and they will work
The Intakes hit the exhaust do not. For Cranes cut down the adjustment nut and set screw assembly by 50% of the actual hex head height and it will clear and still be enough to tighten.
| All times are GMT -5. The time now is 11:51 PM. |
