-   -   Warning Fram Oil Filter Recall!! (https://www.offshoreonly.com/forums/general-q/179232-warning-fram-oil-filter-recall.html)
CPPerformance 02-06-2008 02:47 PM
1 Attachment(s)
WARNING FRAM FILTER RECALL!!!
Beware Fram has a recall on the popular HP-4 oil filters. Please see attachment. The rubber o-rings are blowing out and puking all of the engines oil.
jrz 02-06-2008 03:02 PM
Thank You
I have something to check tonight.
Raylar 02-06-2008 11:45 PM
With all the really good oil filters out there in the market, why would anybody by a Fram filter for use in an expensive marine high performance engine. Take the good ones and a Fram and cut them open and compare, it will most likely be the last Fram you buy. Remember that generally when big corporations spend more money on advertsizing than on product improvements the product usually suffers!. Make it sound good a sell a sh**load of em!
Regards,
Ray @ Raylar
cig1988 02-07-2008 03:27 AM
Regards,
Ray @ Raylar
Ray
What would you suggest in replacement to the HP-4's?
Vinny P 02-07-2008 05:58 AM
Ray,
I wouild also like to know which you recommend. I am running a Fram HP-6 A. I thought they were the filters to run. I am also surprised that the HP-6A is not part of the recall. Maybe because the case is bigger?
320es 02-07-2008 06:55 AM
I agree with Ray. Fram filters suck. They just have better marketing than yhe other guys out there. I always use WIX on all my vehicles. On my boat I use the WIX 51060R. It is the wix replacement for the hp4.
Croozin2 02-07-2008 07:21 AM
Exactly what I run on mine. Wix F/W separators as well.
CigDaze 02-07-2008 07:22 AM
FRAMS are junk. I wouldn't put them in a 20-year old beater.
Great thread here:
http://www.offshoreonly.com/forums/s...ad.php?t=86056
Dock Holiday 02-07-2008 11:07 AM
Very interesting read and I appreciate the information.
Guess I have been one of the lucky ones as I have used the HP4 now for six years with no problems at all.
Now I have to figure out what to do with the four I have in the shop.
I think I will do the cut open and compare test.
mrhorsepower1 02-07-2008 12:31 PM
Regards,
Ray @ Raylar
All I run are Fram filters with ZERO issues. The Fram in relation to others is a high flow/high volume filter. Everyone can run what they want, but from our 50 plus years we choose Fram .
Joe92GT 02-07-2008 12:41 PM
If you need really high flow through the filter, why would you use a fram? I don't understand, less filter media means less flow! Especially when it clogs. If for some reason your oil filter didn't flow enough, wouldn't two in parallel be a better choice?
no fram for me, EVER, and this isn't a new thing. I have never used frame since seeing both insides.
mrhorsepower1 02-07-2008 03:23 PM
Actually, We don't have to worry about metal particles and such...........maybe we just won't use one at all!:rolleyes::D
Strip Poker 388 02-07-2008 05:48 PM
3 Attachment(s)
I use the Wix .Wix makes most of the filters for Napa,just get the ones with the R in front of the part #They cheaper there also.
You can also get the fuel filters there,Theres a thread on the fuel filters here also.Ck out the fuel flow,gallons per minute
http://www.offshoreonly.com/forums/s...ht=fuel+filter
Originally Posted by Strip Poker 388 (Post 1582237)
I run the Napa /Wix filters. I did a little :rolleyes: research when I built my blower motors , Probably over kill and anal. but I know I don't have a fuel flow prob.
They have more flow capability's than most.
I have a different adapter than the merc stuff its a 1x14 thread.
Tere is some #'s to give ya an idea.
#3005 flows 15gpm has a 3 micron rating and also had a drain in it measures 7.3x3.6
#3604 flow 15gmp 8 microns 9.7x3.6 it bigger
3604xe has a 2 :eek: micron rating same flow
The XE series must have a different element inside for the smaller microns
For the fuel filter adapter base like Teague,Cp,Trick has a 1inch x 12 thread Teagues filter is a fram it was the worse.Trick uses the wix.dont remember on the CP
Part #'s
3418 flows 12-15GPM at 12 microns 8,419x3.698 about 8.00 at Napa Jobber
#3123 15gpm 12 micron measures 6.629 x3.698
they all are about the same dia . the length makes a differance in flow.
Napa Wix filter tech line 1800-949-6698
I ck with Teague and CP they rate theres at GPH Not GPM-Gallons Per Minute!!! So when they say it flows 140GPH it flows 2.33 gallons per minute
Hope this makes ya think
Rob :drink:
MM1 02-08-2008 01:03 AM
If you filter clogs you have way bigger problems than what brand it is. More like which bearing it is and if the motor has that much material flowing through it its no going to matter what brand filter is on it.
mrhorsepower1 02-08-2008 06:28 AM
You took the words out of my mouth brother!:D
KAAMA 02-08-2008 07:31 AM
There was another thread on filters/Fram filters compared to some other brands a few months do a search.
Strip Poker 388 02-08-2008 12:25 PM
True,Like panning for gold in your oil pan:D
Ive really have never heard anybody having a oiling problems with big block Chevys.I guess its over kill/good insurance
MM1 02-09-2008 11:47 PM
I run the HP 4 filters on my personal boat as well as customers boats above 400 hp.
OldSchool 02-10-2008 07:51 AM
I just went out and checked the two that I have in my garage and the numbers match the recall.:(
fund razor 02-10-2008 08:48 AM
I must have an old version of acrobat reader on this machine.
I tried to open it to answer my own question but no luck.
Wanted to see if it was just the 4, or if the 5 is also effected.
I use the 5 in my pickup all the time. (Used Mobil 1 in the boat tho) I change the oil in the truck frequently here at the house. I have had no problems with the 5 so far.
If the 5 is involved, I'll change it out.
I did once have a bosch that crushed when I put the filter wrnech on it, and it wasn't that overtightened.
