Exhaust
For the same money, which would be better? Lightning Marine standard jacketed header, or Stainless Marine Hi-Torque manifolds?
Goes on 454 Mag with procharger... |
Originally Posted by trawfish
(Post 2436277)
I am a distributor for both as well as lightining. While I do like many of Emi's products as far as the exhaust manifolds the Stainless marine system is really a great product that is hard to beat on many points.. :) Jamie / Lakeside
What is the factory warranty period offered?
SM has 5 year, that is one reason why I went there! does not matter about Salt Water....Brownie says that if you flush after each use...the life should be lots longer than the warranty period.... my $.02
If they offer XX months then you have some reason to believe that with proper care you should AT LEAST get that out of them because how many builders want hassles of warranty issues? |
(Post 2436277)
Goes on 454 Mag with procharger... http://www.cpperformance.com/product...ne-exhaust.htm http://www.cpperformance.com/product...ng-headers.htm |
We have used Lightning's headers for over 5 years... excellent performance, no cracking or rust issues ever. We do however use automatic drain tubes on the headers to drain after every time in the water with no hassles. Besides, the Lightnings look a lot better than the cast units.:D
| All times are GMT -5. The time now is 02:15 PM. |
