-   -   Ford starter solenoid use for stereo amp power switching (https://www.offshoreonly.com/forums/general-q/179409-ford-starter-solenoid-use-stereo-amp-power-switching.html)
US1 Fountain 02-20-2008 10:07 PM
Originally Posted by hunster (Post 2453654)
Still think you are throwing a band aid on the problem. If the amps arent shutting off when 12v is removed from the remote turn on , there is something wrong with them. There should be no drain.
I tend to agree.
I talked with the shop that I bought my amps from and he stated it's not uncommon for them to have some draw. So not sure how much I'm going to gain by taking then in to have them check them. Plus I've read it a some stereo forum others having same issue, mainly on the cars that sit for a week or so between starts where it is more of a problem. So I just assumed it must be then.
I had checked the current draw with them off and found the mono amp to draw 32mA, 4 channel amp drawing 2mA using a high quality Fluke meter. These numbers being so low don't seem like enough to kill my battery, but in 2 weeks time, dead. Less than 1 yr old battery had checked out good.
