LCD and DVD Install
I'm trying to install a Sharp 19" LCD and a small (possibly portable) DVd player.
I have to admit that my electrical knowledge is limited. My boat has an inverter/charger that works when shore power is connected. I also have a regular home type 120v outlet below deck near the lcd placement. I know many say you can just wire the tv right into a 12v system IF the tv came with a power cable that has one of those little transformers...but mine doesn't. Here are the specs on my lcd: Specifications Screen Size Class 19" Diagonal Measurement 18.5" Panel Type Active Matrix – TFT TN LCD Pixel Resolution 1366 x 768 Tuning System ATSC/QAM/NTSC Brightness 300 cd/m2 Viewing Angles 160º H / 160º V Lamp Life 50,000 Hours1 Audio System 2 watt x 2 = 4 watts total Contrast Ratio 400:1 Aspect Ratio 16:9 HDMI™ Input HDMI™ Input x 1 PC Input Analog RGB 15-PIN DB15 x 1 Remote Control Timer Remote with Magnetic Back Component Input Y/Pr/Pb x 1 S-Video Input 4-pin DIN x 1 Composite Video Input (A/V) RCA x 1 Audio Inputs RCA L/R x 4 Audio Outputs Headphone Jack 3.5mm, Digital Audio Output x 1 Power Consumption AC 45 W Power Source 120V So, it does not appear my TV can run directly off 12v. Can someone help me with some pointers on how to wire this thing in so I can watch it when I'm under anchor with nothing running?? Right now it works fine plugged into the outlet, but only when connected to shore power. I need to be able to watch it for exteeded periods of time. Thanks in advance. EDIT - I am also willing to purchse another inverter or whatever quality product I need to get the job done right where I never have to worry about killing my batteries. |
I install home electronics for a living and do all sorts of home automation. You are right, the old-school LCD's had a power pack halfway down the power cord and we hated them. You could never find a place to hide it. Unfortunately in your situation it would be ideal if it dropped the power to 12v.
Anyways, I would use a power inverter with an isolated battery. This way even if it does kill the battery, you wont be stranded. How long it will last…who knows? That would be a question for the company you get the inverter from. They should know how much power the inverter will draw from the battery. I have a sneaky suspicion that you will experience a lot of noise in the picture when using the inverter. Therefore, you may want to add a powerline surge protector w/ clean power circuitry. This will tell you exactly how much power the inverter is producing and will filter noise from the AC power. I would recommend the Monster Power HTS-3600. These retail for $499, but I can get a fellow boater one for $350, you pay shipping. You may find this for less on the Internet. Whatever works best for you. http://www.monstercable.com/productdisplay.asp?pin=3259 Hope this helps. |
Thanks Quaid - I was thinking about just running an inverter like this:
http://cgi.ebay.com/XANTREX-PROSINE-...QQcmdZViewItem Wire the inverter directly into my main electrical panel on it's own breaker and then install one of these in the engine bay: http://cgi.ebay.com/ws/eBayISAPI.dll...ksid=p3907.m29 Generator as a safety precaution so I know I can always run it under anchor and then one of these stowed away just incase I need a jump: http://www.battery-rechargeable-char...t-VEC012B.html Thoughts ? I'm anal I know but lets not go there :) |
1 Attachment(s)
This is what we did . We used a Magnavox 15 inch $219.99 and a Farenheit DVD61 in dash player $89.99 and it all ran off 12 volt. :D
Placing or installing a generator like that in the engine bay might not be a good idea. The gas tank is going to vent directly into the engine compartment. All these vapors need is a little spark and you know what happens next. BOOM! You certainly cant run it in there because of the carbon monoxide.
I would leave the generator out of the equation and just install the inverter. The jump-box is a great idea though. The guy with the formula has a pretty good solution as well. Just use all 12v products. |
Dvd Lcd
I would never use an invertor unless it was as a last resort, emergency/just no other way to power a device. I certainly wouldn't plan it that way. There are plenty of 12VDC DVD's and LCD's available. Inversion is just a terribly inefficient use of available DC power.
The inversion/conversion efficiency from 12VDC to 120VAC is extremely poor just by nature and the invertors are no where near 100% efficient either. Even the best ones are in the 90% range. That is, for every 100 watts of 12VDC you get only 90 watts/12OAC before the voltage conversion. A conversion example is 1 amp load @ 120VAC = 10 amp load @ 12VDC. 1 amp @ 120VAC is not much of anything at all yet uses 10 amps @ 12VDC. There's no room on my boat for anything that inefficient. Anyway, many 120VAC LCD monitors have a PSU that converts 120VAC to 12VDC. Just look for one that ends up @ 12VDC at the LCD. Invertors will draw power from your battery just idling with no load because they are a a load to the battery them self. Just my two cents worth. |
Originally Posted by deboatmon
(Post 2446376)
The inversion/conversion efficiency from 12VDC to 120VAC is extremely poor just by nature and the invertors are no where near 100% efficient either. Even the best ones are in the 90% range. That is, for every 100 watts of 12VDC you get only 90 watts/12OAC before the voltage conversion. A conversion example is 1 amp load @ 120VAC = 10 amp load @ 12VDC. 1 amp @ 120VAC is not much of anything at all yet uses 10 amps @ 12VDC. There's no room on my boat for anything that inefficient. Anyway, many 120VAC LCD monitors have a PSU that converts 120VAC to 12VDC. Just look for one that ends up @ 12VDC at the LCD. Invertors will draw power from your battery just idling with no load because they are a a load to the battery them self. Just my two cents worth. I have a 2500 watt inverter in my truck running my 13 cu. ft. refrigerator when I come home on friday I dont start my truck untill monday and it fires up every time it only has 4 batteries. Just my real world experience |
Originally Posted by Quaid24
(Post 2446315)
I would leave the generator out of the equation and just install the inverter. The jump-box is a great idea though. The guy with the formula has a pretty good solution as well. Just use all 12v products. My problem with using a 12v display is that none of the ones I looked at will fit my install space, and the ones that do are just simply too small and look like crap. EDIT - I was also thinking isolating the gen exhaust and routing it into an existing exhaust line.... |
(Post 2446376)
Invertors
Sounds like there's plenty of invertor users out there. diggster69 I'm sure you are having success with your invertor because you say you are. The situation you describe is fairly easy on batteries. You're not opening and closing the fridge door during the time you mentioned so it probably doesn't run too much. And, four batteries is a pretty healthy battery setup. If you want max invertor power use 6 volt golf cart batteries hooked in series. Run 4 batteries in a series parallel hookup. Talk about some current, that's the hookup. That's a great battery combination for invertors.
Never, ever, ever place an invertor in the engine room. That's a recipe for disaster there. The electrical math simply does no lie though. It's just more energy efficient to run 12VDC components when you can. They are readily available. Go to SAM's. Many of the LCD TV's they have will run fine on 12VDC. They come with a wall wart plug in power supply to plug into the wall outlet but many are putting out 12VDC. It is an indisputable fact though that the invertor being between the load and the supply reduces the efficiency because there's not an invertor made that operates at 100% efficiency. deboatmon |
| All times are GMT -5. The time now is 12:20 AM. |
