-   -   Oil Pan choice for 572 - 598 (https://www.offshoreonly.com/forums/general-q/179843-oil-pan-choice-572-598-a.html)
IRONMAN 02-14-2008 07:09 AM
Will a Merc 500 Bulldog 540" oil pan work well on a 4.5" stroke motor?
What other oil pans should I be looking at for a dart block?
mrhorsepower1 02-14-2008 09:28 AM
I use alot of Stef's marine offshore pans. I am a WD and can get you a great price.
cstraub 02-14-2008 05:38 PM
OEM Core pans can hit the the main caps on a Dart block. 4.5" stroke will require a pan with stroker notches. I would recommend taking Dean up on his offer and go with a Stef's Offshore pan.
IRONMAN 02-14-2008 07:58 PM
Will the Stef's pan be able to be used with a Bravo setup as well as a Transmission setup, I would like to have the option to change drives in the future and prefer to use the bottom mount starter for now.
cstraub 02-15-2008 10:09 AM
We can put a start notch on it no problem for a tilton style starter. Our pans are complete with welded pickup to a Melling pump and are test fitted for each application. Won't be a problem for what you want. Pan includeds the bracket for the waterpump, windage screen, and mounting hardware. Dean will take care of you.
