-   -   MSD 8.5mm Plug Wires (https://www.offshoreonly.com/forums/general-q/180746-msd-8-5mm-plug-wires.html)
axapowell 02-26-2008 12:41 AM
Anybody have a part number for MSD 8.5mm wires that fit a HP500 Carbed motor? I will build them if I have to, but I am looking for a pre-made set. Running the stock Merc distributor and need 90* boots at both ends.
Thanks,
Dave
mrhorsepower1 02-26-2008 06:00 AM
I can order them for you I am a WD for MSD.
rchevelle71 02-26-2008 06:18 AM
Would these be the same as a 454 330?? I will also need a set.
C_Spray 02-26-2008 07:13 AM
I just went through this, and wound up buying Taylor 8.2mm Thundervolt wires - $69.99 at Summit TAY-83253. They are available in blue and black, too. I did have to put the distributor ends on, but that was by choice - I wanted them to fit exactly right. Most of the wires were pretty close right out of the box, but everyone routes them just a little different. Fortunately, I had access to the special strippers/crimpers needed.
KEPP 02-26-2008 10:39 AM
Thanks,
Dave
The part number you are looking for is a #120-31489 8.5MM wire set. We have loads of them on the shelf and they are only $83.99. Our phone number is 386-446-0660 or feel free to shop securely at our website here the product link http://www.keitheickert.com/detail.aspx?ID=477
RaggedEdge 02-26-2008 06:06 PM
Thanks,
Dave
Call me, I've got new wires i bought for the 500's that I never used, and thinking I never will with the 525's. You've got the number.
axapowell 02-26-2008 08:23 PM
Thanks everyone...
Dave
offthefront 02-27-2008 12:11 PM
I just installed 2 sets of MSD 8.5's and they are nice wires cept I was dissappointed in the length's ... I might have ordered the wrong ones but as close I could see was BBC "under headers" They worked but I had to use my "plug wire stretcher" to get some to reach ...m
Elite Marine 02-27-2008 06:17 PM
http://www.cpperformance.com/detail.aspx?ID=477
Let me know if I can help guys.
