-   -   Serpetine Belt (https://www.offshoreonly.com/forums/general-q/181029-serpetine-belt.html)
31scarab31 02-28-2008 08:09 PM
Serpetine Belt
Looking for some information on converting from VBelt to Serpentine. Looking for brackets and correct offset pulleys? :cool-smiley-027:Throw the daigo some knowledge please!!!:cool-smiley-027::cool-smiley-027::cool-smiley-027::cool-smiley-011:
MOBILEMERCMAN 02-28-2008 09:24 PM
Its a pretty involved change. I'm not aware of any kits. Is there a good reason to make the change? Seems torturous and expensive with little upside.
31scarab31 02-28-2008 11:01 PM
Jim thank you for the information, you made my decision. Can you help me with my next decision? Your expertise would be greatly appreciated.
Twin 555 CI
750HP
large custom Sea Strainers
Should I use a dual cooler (trans & oil) with each engine or should I have two single coolers for each engine?
scarabfun 02-28-2008 11:04 PM
i'd use two seperate coolers on that
31scarab31 02-28-2008 11:13 PM
Any Pro's & Con's?
Hardin Marine 02-29-2008 12:01 PM
Gentlemen we do offer a serpentine drive kit that has become the standard for many professional engine builders today. In order to do this system it just doesn't really justify due to cost unless you have nothing already since it comes with every accessory as well. There is no way to convert an existing v-belt system effectively. Just thought I would post you an example. http://www.hardin-marine.com/detail~ID~1115.aspx
MOBILEMERCMAN 02-29-2008 03:58 PM
Since you don't have stock power you should use two separate. I think trannies use about a 12" cooler and the engine needs a least that. Don't think you can find a combo big enough for what your doing.
31scarab31 02-29-2008 04:12 PM
Jim,
Thank you for the quality information, it is greatly appreciated. I checked out your race pictures and read your bio. Congradulations on your big wins!!! Great luck with finding some sponsors and getting back behind the wheel! Again thank you for the help!!!
CPPerformance 02-29-2008 05:13 PM
The picture on your website does not do that kit justice. Here is what I think is a better picture.
http://www.cpperformance.com/ebay/la 2008/drivekit.jpg
MOBILEMERCMAN 02-29-2008 08:41 PM
31scarab31, you are welcome and thanks.
CPPerformance, Nice looking stuff thanks for sharing.
31scarab31 03-04-2008 01:57 PM
Thanks for the picks! That looks f awesome!
C_Spray 03-04-2008 02:14 PM
...and priced accordingly. Don't get me wrong - I'm not saying it's not good value, just a lot of coin if all you wanted to do was "convert over".
I just finished converting my engines (see "Project.....382" in the Formula Owners forum), and did the work myself. I found commercially-made (steel) pulleys for the P/S pump and alternator, but had to do all the head-scratching on the modifications to the mounting bracketry to get the correct offsets. I did my own machining to the crank and water pump pulleys - got the proper Kennametal cutting tool from a friend who has a machine shop. I had the time and resources, so I went for it myself. Took about 3 days and $100.
