-   -   Rebuild raw water pump body? (https://www.offshoreonly.com/forums/general-q/181219-rebuild-raw-water-pump-body.html)
handfulz28 03-02-2008 06:58 PM
Not the impeller, but the actual pump body. '91 Mark IV Bravo. I've got one that the shaft is turning rough and a little notchy. The parts diagram shows the internals for the old 2-piece body it looks like. Not sure if the parts are the same or not.
offthefront 03-02-2008 07:43 PM
Mike .... I rebuilt one and it worked out fine .... We crossed all the parts from the local bearing Company ... it was about 25-30 bucks .. you can get the parts from Merc though ... seems it was about 50.00 ...
you do need access to a press ....
handfulz28 03-02-2008 08:09 PM
Thanks Mike.
That'll be the sticking point. So did you use the special Shell #2 grease? Where the heck do I get that?
