-   -   Pressure test oil cooler (https://www.offshoreonly.com/forums/general-q/181292-pressure-test-oil-cooler.html)
Lee 03-06-2008 05:49 AM
Originally Posted by nocigarette (Post 2469755)
I was hoping you would chime in wobble.....It is weird i threw the whole thing in my hot tub and not a bubble, but after two days it has lost ten pounds of air, i think it is pushing through the threads real slow...I hate to risk it though....
Air pressure will change depending on the temperature. In other words you can have a pressure drop on your guage and not have a leak.
hoozeyurdaddy 03-06-2008 08:37 AM
With that kind of air pressure, and submerged, if there are no bubbles coming out, there are no leaks, water temp will change the pressure but bubbles are the answser.
nocigarette 03-12-2008 09:20 AM
Originally Posted by Wobble (Post 2470082)
that is strange, try a different gauge:D
actually, soapy water may show a leak that you might otherwise not see, that includes the gauge
Slightly bubbling from the gauge, a little twist from a wrench and no more leakey.......
Thanks for the help, i am just really anal about everything being perfect this time.....
