-   -   Crane Valve Springs (https://www.offshoreonly.com/forums/general-q/181798-crane-valve-springs.html)
deboatmon 03-10-2008 10:28 AM
Crane Valve Springs
I recently had a valve spring problem with my 502'S. My motors have Crane Cams, rockers, and dual springs. Recently a spring broke and my mechanics have just informed me that there is debris under both valve covers. Not good at all. Total top end overhaul is at about 200 hrs. only. My engine is not max performance by any means. Built to resemble 500EFI.
Suggestions for spring replacement. Crane doesn't seem to be what's best for my motors.
Strip Poker 388 03-10-2008 02:49 PM
comp 929 set of at 1.880 around 145lbs
formula 382 sr-1 03-10-2008 04:39 PM
Isky 8005 SP.:D
Inspector 03-10-2008 07:52 PM
Cam specs?
What are your cam specs and what crane springs are you using?
H2Xmark 03-10-2008 09:21 PM
i had an inner spring break at 170 hours, are any springs lasting more than 200 hours with .600" valve lift?
Strip Poker 388 03-10-2008 10:56 PM
mine have about that on them,they still ck 155lbs at 1880,buz it up to 6000-6100 on hard runs
MM1 03-10-2008 11:56 PM
Originally Posted by formula 382 sr-1 (Post 2479099)
Isky 8005 SP.:D
I agree
JIMG 03-11-2008 08:07 AM
crane had problems with certain springs being hardened inproperly. they would break & leave debri throughout the engine. Had this happen to my engines. they did replace my springs & lifters for free. I had to pay for the rest of it. mine happened a couple of years ago, with the springs being installed maybe three years ago at this point. (they broke the first season)
H2Xmark 03-11-2008 07:08 PM
i went with the crane springs again Part Number: 99895-16, i guess if they last me another 170 hours I will be ok with that. if these dont hold out guess i will try Isky or Comp cams
formula 382 sr-1 03-11-2008 08:07 PM
We just pulled an hp500 out of a 99 29 Fountain 230 hrs 14 of the 16 valve springs were broken. I was told that crane valve springs break in the box.:D
