Distributor gear Part#
My merc dist has a .425 shaft which the standard gear doesn't fit. Has anyone run across this before?? If you have what part # is it and can you get from GM.
You sure you got the shaft diameter right? These are the sizes that are listed at Summit Racing.
Distributor Shaft Diameter: 0.500 in., 0.491 in., 0.467 in., 0.531 in., 0.490 in., 0.484 in., 0.530 in., 0.427 in., 0.489 in., 0.468 in., 0.466 in. |
It is the .427 gear. Some BBC and SBC and V-6 apps. I need to find out if they have a melonized gear this size.
The GM part# is 19052845 and it is a hardened (melonized ) gear. GM sends what they have to Merc and this happened to be what was put in mine. It is the small cap,external coil HEI dist.
Jim Pace has it. I need to order one for Bill. Let me know if you want me to get one for you.
Eddie http://paceperformance.com/index.asp...D&ProdID=72159 |
They are available also for in LH and RH rotatation.
SH*T!!!!!!!!!!! I hope I got the right one!
