Stainless Bolts on Exhaust Manifolds
Is there any reason NOT to use stainless bolts on my Exhaust manifold? I thought it would make it easier if I have to remove them in the future and cause less of a problem with rust. However I got to thinking (ussually a dangerous thing) and thought that there may be a reason not to do this like dissimiliar metals or something.
Jon |
Ive used socket head (allen) cap screws for years against gil manifolds with no problems. I think the socket heads are easier to install and tighten than hexhead bolts. By them from McMaster Carr. Oh, I used flat washers too.
My Imco's came with Grade 8 bolts and no washers. I think the SS bolts may not be strong enough. If they are in there a few years and start to sieze you could break them trying to remove them. Also due to the SS being softer metal it will make the head easier to strip.
I replaced all my original bolts with SS on intake and exhaust manifolds. Haven't had any problems. In fact on my other boat, the volvo penta outdrive, which in my opinion is engineered better than mercruiser, uses all stainless socket head cap screws. What a joy to work on, even with just under 1000 hrs run time and generally kept in water from April to November.
Grade 8 bolts are typically misapplied because people think they are stronger. They are in fact harder and therefore you can get more clamping force, but the drawback is they are brittle. That makes them unsatisfactory in applications where the clamping surfaces are not perfectly parallel and a side load is applied to the underside of the bolt head. When you add vibration to this scenario you get breaking bolts. Most surfaces on engines are not perfectly machined and therefore a bolt tough enough to bend is the best choice, usually a grade 5. My .02 BT |
Use an anti seize lube and they will be fine!!
Oh yea, Neversieze for sure. Messy but it works. Especially any stainless to aluminum threads.
Since there's differing opinions here I'll toss another factor in. SS is an OK choice for header bolts but you need to check them more regularly than CS (carbon steel). Since SS has a fairly high chromium and nickel content it also has what is refered to as a high "carbon equivalent". Carbon is the element that determines an alloy's hardenability. Other alloying elements equate to a "carbon equivalent" which is used to compare hardenability.
So, with lot's of alloying elements like SS has, it is very hardenable and therefore will become brittle when hardened. What causes harndness in a hardenable material? One) heat treating, or two) work hardening. What does this have to do with header bolts since (even though they get pretty hot) it doesn't get hot enough to change the molecular structure (heat treatment)? Tightening a bolt causes it to stretch and bend; in essence to "work". A material that work hardens readily will get harder and therefore more brittle each time it is "worked". So after tighteing a SS bolt a few times it may get hard and not provide the required stretch to ensure that it will stay tight over time. Alls you gots to do is check them, and if they don't stay tight after given a chance for the gasket to set, etc, you may have to replace a few. A small price for nice clean header flanges in my mind. OK - here's a quiz (since I've so effectively transported my mind back to my metalurgy classes and I'm in a fairly geeky mood): Why is SS so difficult to cut gently but can be cut rather easily using aggressive tools? :confused: |
OOOO, ooo, me, me, pick me, I know this one!
Its because SS work hardens if you take a small cuts. You need to takee heavy cuts to continue getting into fresh, un-work hardened material. I've never had a SS bolt break on me due to repeated tightening. That is an intriguing thought though. I can see how that could happen if a SS bolt is torqued to the upper end of it's elastic limit. I thought the work hardening process didn't start until the material passed it's yeid point? Therefore if torque properly the hardening shouldn't ocurr. Great topic! BT |
Use a grade 5 Carbon Steel Bolt. They are much more forgiving than Stainless Steel and always apply a graphite anti seize to the threads. I am very carefull when it comes to connecting dissimiliar metals and I don't do it unless I have to. You can experience galling with SS threads if conditions are not right, and that can get real ugly.
I have always replaced about every bolt with SS also always in aluminum for corosion reasons. never has there been a problem.
One thing carbon grade 5 bolts usually have cut threads SS are usually rolled and dont chew up aluminum as easy. |
All very true and informative stuff. I work with SS pretty much exclusively in my industry and the standard 300 series bolts are not very good when holding power is needed. Since the Gil manifolds are supposed to be torgued to no more than 25 ft/lbs (I think), I havent had any issues with them. If I need something stronger I make them out of 17-4 and heat treat them. For engine mounts (through stringers or to the block) always use grade 5 bolts. I have seen SS bolts break off and drop engines in the bilge. Everyone should check there engine mounts because lots of maunfacturers and riggers use ss bolts for this and they will break or shear. Also dont use ss for any brackets that attach accesories to the block.
I'm not trying to dispute anyones word, but back 30 yrs ago when I was in the fastener business, threads were rolled on mass produced bolts. Cutting would be slow, wastefull and messy. Although technology changes over the years and maybe that is what they do now. However,I'm not sure we are helping Audiofin with making his decision on which bolts to use.
Since when was it the purpose of the board to help anyone? I've always figured the best use of a message board was to confuse people with a bunch of miscellaneous technical ramblings by people that only think they're qualified to go on and on about stuff they know nothing about. Like me.
Hey Blue - you win! But guess what, my header bolts are carbon steel... ...and my oil is... |
Oh Crap!....?
All my bolts (engine mounts included) are SS. They are ARP SS though. I think these are much better than the garden variety alloy found in hardware stores. They hold all my accessories and manifolds in place without a problem (oil pan too!). Good thoughts about the motor mounts though. I do have the garden variety on the rear of the bell housing. Need to probably change those. |
I have used SS bolts on all of my accesories, pulleys, intakes and exhaust on a number marine engines and have never had a problem. Although on things such as motor mounts I have stuck to the grade 8 bolts.
One question I do have is should you use lock washers or flat washers on the bolts that secure the coupler to the flywheel? |
| All times are GMT -5. The time now is 07:41 PM. |
