-   -   Sea Pump leaking oil? (https://www.offshoreonly.com/forums/general-q/183820-sea-pump-leaking-oil.html)
MILD THUNDER 04-05-2008 08:52 PM
Was playing around with my new to me boat today. Noticed what looked like grease "slung" in the bilge. The line of grease/oil seems to line up with the sea pump pulley. Its not motor oil, its too thick and blackish gray in color. I am pretty sure its got to be leaking from the sea pump.
Does merc have a seal and bearing kit for these old style pumps? Its the Gen IV pump.
offthefront 04-05-2008 09:14 PM
yes it is the pump ...
Part .... # 13 15 16 19 and if you need the shaft #17 ....m
http://www.mercruiserparts.com/Show_...SEA+WATER+PUMP
MILD THUNDER 04-05-2008 10:10 PM
THANKS! Thats what I was looking for!
Wobble 04-05-2008 10:29 PM
Could it be that your belt is slipping, that will leave a black carbon type line also.
MILD THUNDER 04-05-2008 10:33 PM
Nah, its definitly a oily grease residue. Its actually splashed on the stringer(portside) and underside of hatch. Probably leaking from the pump shaft, then getting slung clockwise from the belt/pulley.
offthefront 04-05-2008 10:45 PM
there is a hole in the housing ...when the seal starts to leak water/grease comes out of the small hole .....m
Jerry B 04-07-2008 11:59 AM
If you have the mechanical fuel pump bolted to the sea pump make sure it not leaking fuel into the pump housing. It will delute the lube thats in there. I think it uses the same lube as your outdrive uses. I had this happen on one of mine. Had to replace front seal and fuel pump. I took the seal to an auto parts store and they had a match.
