scarab hard alarm
i have a 1998 scarab 33 AVS w/ hp 500 carbs.
it has developed a hard alarm on the starboard ignition just turning the key one click right (hard alarm with no engine running) and stays on with the engine running. this is not the normal start-up alarm. the depth gauge is on the port ignition. all gauges read normal, all fluid levels are good including drive and the boat runs great. most sensors have been tested (unplugged) and the alarm continues. i'm beginning to think that this isn't even related to the engine. any thoughts? thanx jim |
On carbed engines, the alarm is hooked up 3 things.
Drive lube bottle Oil pressure Water temp The wires going to the alarm sensors are tan with a blue stripe. |
the sensors have been checked and double checked. what bugs me is the hard alarm is sounding without the engine running, isn't that strange?
the engine has to be running for the sensors to be activated, correct? |
no on my 33 avs it would buzz until it built more than 5 psi of oil pressure then would go off..
Nope,,, the oil pressure alarm will sound without the engine running.
You will get the initial alarm,,, silence,,,, then oil pressure alarm will go on until you start the engine and it sees pressure then it will shut off. Keep in mind there are 2 sensors for oil pressure. One for the guage, one for the alarm |
am reading 60 psi on the oil pressure gauge. all gauges are reading normal. keep 'em coming.........
the hard alarm comes on immediately when i turn the key one click right, no intial alarm or silence, comes on straight away. thanx so far guys jim |
The readings on the guages don't matter. The sender for the oil pressure alarm is different than the sender for the guage as the sender for the high temp alarm is different from the guage sender. The alarm senders use a tan wire with blue stripe.
It can only be one of the 3 I listed. Unplug each sender one at a time. The alarm will not activate if they are unplugged. If the alarm is still going off, then one of the wires from one of the senders is grounding out. I actually had two wires that were spliced together to one of my drive bottles pull apart last year. The bare wire was touching the engine and setting off the alarm. |
ok, here goes, found three sensors with the tan & blue stripe wire. one was on the drive bottle, 2nd on left side of the t-stat housing and the 3rd on top of the intake manifold close to the t-stat housing on the right side.
for the life of us we could not find an oil pressure alarm sensor. please let me know where this sensor is, this is a 10 year old hp 500 carb engine. pulling the sensors did not stop the hard alarm. if there isn't an oil pressure alarm sensor then i'm looking at a sensor harness short. let me know thanx jim |
It should be down next to where the oil filter would go on a car. RH side lower corner of block
that oil pressure switch was hard to find, i pulled the plug and the alarm stopped. have new switch on order hopefully that will take care of the problem.
if i hadn't seen an hp500 carb on the stand at full throttle marine i wouldn't of known where to look for the switch. it was on the port side (as the engine sits in the boat) down and back tucked up underneath. thanks guys jim |
Glad you found it. Don't put sealant on the new sender when you install it. It grounds itself throught the threads.
Ahhh, the power of OSO! Good work!
Originally Posted by SCARABJ
(Post 2520146)
tan/brown?
On my eliminator I have a tan/brown AND the tan/blue that everyone else has. My buzzer was plugged into the tan/brown and did not work. Wonder if you have a tan/brown also, and why or why/not? I know its a shot in the dark, but maybe your buzzer is plugged into this wire?
Originally Posted by jimishooch
(Post 2520980)
jim |
Originally Posted by US1 Fountain
(Post 2528148)
Why are there 2 sensors at the T-stat housing with the tan/blue wire? Should only be 1.
just to close this thread, it was indeed a bad oil pressure switch. installed new switch and am back to normal start-up alarm.
| All times are GMT -5. The time now is 03:15 AM. |
