Oil Inside Distributor
I"m getting oil up inside my msd distributor not on the intake but inside, not a lot just a little. Is there any seals in the shaft that need to be replaced?
punn it out. press out the pin in the gear. slide out the shaft with the reluctor wheeel on it. change em up. check housing while bushing is out. put it back in.
| All times are GMT -5. The time now is 01:47 PM. |
