-   -   1999 Supercharged 454 problems (https://www.offshoreonly.com/forums/general-q/185287-1999-supercharged-454-problems.html)
lilwigs 04-25-2008 07:57 AM
The highest I've seen it so far is right around 170, but then as soon as I run full throttle (or as close to full as it will get now) it goes down to 120 in a matter of a few seconds.
kennyo 04-25-2008 09:06 AM
At 3800 rpms you could be getting detonation which would cause this and possibly your fuel fluctuation. I run a t-stat without the guts and mine runes around 110-120.
lilwigs 04-25-2008 10:29 AM
kennyo, I think you are onto something here. My guts says its getting detonation. On an efi, how do I correct this? I ran it would thermostat at first and running at 110 has the same cutout at 3800. I wants to run faster I can tell and plenty of power it wants to make...it just can't.
Knot 4 Me 04-25-2008 10:47 AM
Stock or aftermarket injectors? Same for fuel pump?
lilwigs 04-25-2008 11:00 AM
Believe the injectors would be stock, but the fuel pump seems to be upgraded. I unfortunately know nothing about this area. the fuel system runs though a red canister looking thing which appears to me aftermarket. My concern here is its not my dream boat and am at the point were I don't want to put much more into it so looking for the cost effective solution to get me through the next year or two till I upgrade.
Knot 4 Me 04-25-2008 11:07 AM
A cost effective solution would be to take off the Procharger and put the motor back to stock. You could sell the Procharger and the boat would have better resale potential when you go to sell or trade it. Let's face it, a 2330 Chap is not a performance boat. And I'm not knocking Chaparral, I own one.
HTRDLNCN 04-25-2008 11:21 AM
Be very careful with a blower on a non-Mag 454, you will cook a cast piston sooner or later unless your uber careful and have a perfetcly tuned setup.. I did it without a blower on my Chappy
lilwigs 04-25-2008 11:40 AM
I couldn't agree more on the fact it's not a peformance boat. I'd of never put a charger on it myself to begin with. If anyone has any other ideas, I'll keep playing around and paying my mechanic for a little longer then, the charger may just come off. Never running this boat without the charger...would I notice a big difference (its a 5lb boost), other than my hole shot?
Knot 4 Me 04-25-2008 01:02 PM
If it ever ran right, you would notice a big difference removing it. Still, the boat will perform well in stock form.
nwimbush 04-25-2008 01:25 PM
Originally Posted by lilwigs (Post 2537344)
Thanks all! One more...
The mechanic just called and it doesn't appear to be pulling water in from the ports on the lower unit? I had it out two nights ago and it was moving water as I could see it coming out of the exhaust, plus I could see the water temp go up and down based on how I was running so I know it was getting water. could there be a blockage in the water movement to the engine causing it not to suck water? I'm sure the impeller was ok the other night.
:cool-smiley-011:
Presume it's an Alpha outdrive - sounds like the impeller, as the highr temps until you goose it - exactly what mine does every 5 yrs or so. As soon as new impeller, much more stable temp.
When did this start, or has it always done this cut out thing at 3800 rpm, I mean since you owned it?
