Fuel water filters/flow direction
Does the fuel need to come in the threaded fitting in the middle where the filter screws on or does it come from the outside in.
I have an old set of Keith Eickert brackets for spin on filters and they are not marked with the in and out for the fuel lines. Thanks, Jim |
I believe from the outside to the inside.
correct out-side is fuel in ! same as oil filter flow direction !
| All times are GMT -5. The time now is 02:34 AM. |
