-   -   To use or not to use (https://www.offshoreonly.com/forums/general-q/185966-use-not-use.html)
Ken N 05-04-2008 06:30 PM
Has anyone ever used a MEFI 3 programed for a suppercharger on a stock 502 MPI engine.
hillbilly24 05-04-2008 11:38 PM
No offense but that is a really bad idea. It would probably not casue any damage to the engine but it would run like a$$. If you are just using it as part of a diagnosis process that would be fine but if you are intending to leave installed on the boat it aint gonna work out so well.
Smitty 05-05-2008 06:52 AM
It will need to be reprogrammed for you to use it. My guess is that about the only thing it will do is start and idle. It probably won't rev over 200 rpm because it will be overfueling at that point.
Bryan Rose 05-05-2008 06:53 AM
Is your engine supercharged? or is this a ECU you found that has been modified to run on a supersharged motor and yours is NA...
I run one programmed BY Precision marine but I do have a blower on my motor. It runs great!
Ken N 05-05-2008 08:52 AM
do or not
do or not
My engine is not but the ECU that I got was set for a suppercharger.
Griff 05-05-2008 10:47 AM
Then you need to have it reprogrammed.
Elite Marine 05-05-2008 11:02 AM
Sure let us know how it works out!!
All kidding aside, I think the guys have cleared that up for you.
Ken N 05-05-2008 11:05 AM
do or not
Who do you suggest for reprogramming.
Griff 05-06-2008 01:50 AM
I've never had one done myself. Many people have recommend Mark at Precision Marine in the past.
