-   -   trim pump help (https://www.offshoreonly.com/forums/general-q/185998-trim-pump-help.html)
eliminatethis 05-05-2008 07:42 AM
trim pump help
started this weekend at about 91 mph trim set about O roll into the last bit of throttle and one sponson dives down throttles are back down and I notice one of my pop up trim indicators is all in starboard sponson port trim everything is working right run it up again and the same thing now the trim works great but will creep in at 50mph that same side has always been a little lazy does any body now of a way to blueprint the pump and valve assembly AND YES I WAS WEARING MY TEATHER with wrist wrap
monstaaa 05-05-2008 09:08 AM
internall valve issue in the pump or make sure that the manual release if equiped isnt loose.
