Aluminum Oval Port heads
Are the GM Aluminum Oval port heads OK for a 454 or 502 Naturally Aspirated?
I have a ZZ502 sitting in my garage, trying to figure what to do with it. I need to work on my 454's in the Chris Cat (hole in piston on one) thinking of putting in 502 long blocks. So I am 1/2 way there in parts (except cam change). Wannabe |
They work great on my 454. I am very happy with the performance thjat i gained with the ZZ502 heads.
Originally Posted by wannabe
(Post 2549352)
Read the past threads on ZZ502's. There is a couple of good ones that explain how to "Marinize" the ZZ502 and about the heads.
Make sure you change the Oil bypass valve. A friend fried his ZZ cause the oiginal builder and boat owner did not change or block off the original automotive byass. |
| All times are GMT -5. The time now is 11:26 AM. |
