Fast idle on start!
I just finished a new 454MAG MPI with an M1SC Procharger. I have been working out the bugs, but right now I have an issue with start up. Every time I start the engine, it revs to 2000 rpm for litarally 5 seconds and them comes back down to around 850-900.
What could be causing this? -ECU was reprogrammed for this set up. -I swapped out IAC with another running engine and no change. -No vacuum leaks present -If I put code checker on and leave in diagnostic mode this does not happen. |
my engine is a lot smaller, but it revs to about the same but drops down to about 650 pretty quick. I just figured it was the efi doing its thing
| All times are GMT -5. The time now is 12:55 PM. |
