-   -   496 throttle sound (https://www.offshoreonly.com/forums/general-q/186563-496-throttle-sound.html)
apexer 05-13-2008 12:47 AM
496 throttle sound
on a 496 is there anyway to reduce the throttle sound ,you know that sucking sound when you give her?
speedreeder 05-13-2008 12:50 AM
YES, There is a small filter type piece that is called a muffler. It is a merc. part and your local shop can tell you where it goes. They come out alot and get sucked into the motor.
apexer 05-13-2008 01:06 AM
any pics or part numbers,thanks
Griff 05-13-2008 02:22 AM
IAC muffler will help at idle. Part #5.
http://www.mercruiserparts.com/Show_...le%2DShift+%29
techman 05-13-2008 08:08 AM
The intake "whistle" under throttle is usually caused by the spark arrestor. Some are worse than others. My motors have a slight whistle around 1800 rpms than dissapear after that. I friend has a serious whistle around cruise speed, 3100 rpm's that drives him nuts. You can try fiddling with the arrestor or replacing it. A K&N filter might help too.
At idle, it is usually the IAC muffler as posted. Try replacing it or making sure it is in place.
Knot 4 Me 05-13-2008 02:08 PM
I tossed my IAC muffler. Too many stories of them causing problems. No real difference in noise. I did go to a K&N filter and it does a respectable job of cutting down the whistle I used to get at 3,000 RPM.
