blower motor cooling system
Running new engine setup, 540 dart w/8-71 blower with chiller CMI headers with two water inlet a side. What cooling system will work best with this setup?
I would assume from a clearance standpoint you would run a cross over system.
Originally Posted by duke
(Post 2556585)
I'm running the seawater pump to bottom of crossover, set-up with a by-pass the them. housing, from main lines out of thrm housing to exhaust and am going to be running a themostat as last year could not get the temp up, played with restricting the water flow from pump but water temp fluctuated a lot....good luck..Rob
Try running it backwards- thru the manifolds, then into the front of the block. You'll warm the water a little bit with the exhaust manifolds.
