-   -   Hydraulic hosee (https://www.offshoreonly.com/forums/general-q/186699-hydraulic-hosee.html)
splashandburn 05-14-2008 05:11 PM
Hydraulic hosee
Anyone know of a good source for hydraulic steering hoses? I think these need to have stainless steel fittings on them. Any suggestions would be appreciated.
Magic Medicine 05-14-2008 05:28 PM
I imagine you should have a hydraulic shop in your area, they should be able to make up what you need.
Elite Marine 05-14-2008 06:12 PM
Have them made locally or I can get you the hose and fitting to make your own.
Let me know about your set up if you'd like a price - dual ram, single ram, boat length etc...
[email protected]
Kirk
Griff 05-14-2008 11:21 PM
I know when I went to several local hydraulic shops, they didn't have the right fittings for my steering and they were pretty big commercial outfits. They referred me to the aeroquip dealer which had everything I needed.
Jb-fse 05-15-2008 12:13 PM
We Can Make Your Hoses.
Call 586-790-8880 Ext251
Dave M 05-16-2008 09:19 AM
I bought my hose and ends from IMCO. This way you can make them exactly the length you need. BTW, cutting the hose is a PIA.
Rookie 05-16-2008 10:26 AM
At my local Parker hydraulic shop I got 80' of Parker 3000 psi hydraulic hose and fittings to do my system for $56. I had to pay for the fittings and he made the rest out of the extra he had laying around. :)
Mr Gadgets 05-23-2008 09:49 AM
Splashandburn.. your email is not working, I need some info asap.. shoot me your address on email if it is working.. Or call me 616-403-1006
Dick
scarabfun 05-23-2008 06:27 PM
i used a air cut-off tool/ wheel. buzzed right through and clean
offthefront 05-23-2008 08:43 PM
The Imco fittings are real nice and ez to install .... the cutoff tool is the trick ....cept we used an electric one ....m
oldandtired 05-23-2008 09:04 PM
I used hose from discounthydraulichose.com. The stainless fittings were really pricey, so I just went with steel and they have held up just fine. None of my hoses go outside of the boat though. The hoses to the rams are part of the imco kit that I used. I wrapped the hose with masking tape before cutting to keep them from fraying. The fittings to the helm were purchased locally.
Rene
