-   -   496 (supercharged) spark plugs (https://www.offshoreonly.com/forums/general-q/187707-496-supercharged-spark-plugs.html)
Plane Silly 05-28-2008 05:50 PM
Does anyone know an alternative spark plug to the NGK BR7EFS (1094)? I have a Whippled 496 that has them in it now but I can't find them locally and no one has been able to cross them propperly. All the crosses I have looked at appear to be hotter plugs.
ezstriper 05-29-2008 06:51 AM
there is a chart on line just google spark plug chart, and you do not want a hotter plug with the blower, most say 1 colder, Rob
Plane Silly 05-29-2008 09:31 AM
Thats the problem, I have looked at the plugs that cross and there insulators all stick out past the threads, the BR7EFS's do not. So they appear to be hotter plugs. I guess I will just have to order them.
Griff 05-29-2008 12:15 PM
What do they cross to in an AC ??????
An AC R41T is a pretty cool plug and is not an extended tip. Its the stock plug for the older merc blower engines.
rmbuilder 05-29-2008 01:51 PM
Plane,
BR7EF S
Thread….14mm
Hex……0.8125
Reach….0.7500
Seat type…..Gasket
Electrode….Std Nickel
Projected tip…..Yes
The following are a direct cross for the above plug. I would recommend you do examine these side by side to verify dimensions.
AC…..R44LT
Champion….RS9YC
Bosch…….HR7DC/HR6DC
Denso….T20EPR-U
Motorcraft…..AGSF22C/AGSF2
Bob
Plane Silly 05-29-2008 03:39 PM
Thanks a lot Bob!
Whipple Charged 05-29-2008 09:02 PM
Originally Posted by Plane Silly (Post 2573651)
Thanks a lot Bob!
Try www.sparkplugs.com
You can try a NGK TR7IX, iridium fine wire.
Thanks,
Dustin
