-   -   Help if you can (https://www.offshoreonly.com/forums/general-q/188687-help-if-you-can.html)
fountainfevr 06-10-2008 08:52 PM
Help if you can
Friend has 2000 502 mpi. He had a blown head gasket and replaced it. Now it surges on idle, backfires and can only get 42-4500 RPM. (prolly not enogh info to work with but it is a start):rolleyes:
Griff 06-10-2008 10:16 PM
It sounds like the rocker arms are to tight and/or valve is hanging open.
ezstriper 06-11-2008 07:28 AM
ck vacume, sounds like may have a leak, timing set correctly ?
fountainfevr 06-11-2008 08:46 PM
we will check timing tomarrow. How do you bypass the computer to reset the timing?
Airpacker 06-12-2008 03:43 PM
check the 5 and 7 plug wires. might be crossed.
B one 06-12-2008 04:02 PM
Take a can of throttle body cleaner or starting fluid spray small amounts around intake to see if you have a good seal. Don't spray too much just a little at a time. If you have a vacuum leak you will know it.
obnoxus 06-12-2008 04:07 PM
If its stock,, there are not adjustable.
Sounds like he didnt bypass the ECU to time it.
