-   -   496 ho lost RPM (https://www.offshoreonly.com/forums/general-q/189106-496-ho-lost-rpm.html)
verbi69 06-19-2008 11:16 AM
thanks for the input guys!!
verbi69 06-21-2008 11:41 AM
Talked with the servicing dealer yesterday and they looked up the work order. Looks like the fuel filter they put on was not a merc...it is some aftermarket thing, i cant recal the name right now. They hope it doesnt flow the fuel that i need and its the source of my rpm loss. They gave me a merc filter which i will install later today. If the weather holds we should be out on the lake tomorrow. I will keep my fingers crossed and post the findings out.
Thanks for all the help here, it is very much apreciated.
verbi69 06-24-2008 10:33 AM
Hey guys.. A little info....
Changed out the fuel filter but didnt check the plugs on Sunday and went out for a ride.....
The rpm's were still down......I will check the spark plugs.
Another interesting note- the dealer said they installed an extra litre of oil then what the manual called for......could this also be part of the problem??
Budz Motorsports 06-24-2008 10:41 AM
Nah a liter will not hurt!
http://budzmotorsports.com/BMS_Photo..._IMG_05068.jpg
Westcoast 06-24-2008 10:42 AM
Take the plugs out and do a compression check. You may have a damaged engine.
verbi69 09-29-2008 08:08 AM
Just an update as to my findings....
-2 liters of oil too much from dealer oil change along with incorrect fuel filter.....
-engine overreved and put into guardian mode
-crankshaft position sensor code activated-upon start up 350 rpm
-camshaft position sensor code activated- ypon start up also
-Cleared all codes, drained oil to proper level and seems to run a constant 4900 rpm, cannot trim anymore or the boat will loose mph.
Thankx to all that have help with their input, it was greatly appreciated!!
Mike
